If the audio track in the DivX is already 44100Hz ,Mpeg layer3,2ch stereo do I still need to uncompress it when cutting the Divx using Virtual Dub. Can I just cut the DivX in half and convert the half as is? Thanx in advance
You can try and it may well work fine, but to avoid various problems with audio sync and quality it is generally accepted that uncompressing the audio with vdub before encoding with TmpGenc is more reliable than not doing so.
Oops... If your going to cut the DivX in half, then later you would save out the audio in each half not before you cut it.
Unless Vdub complains about the audio, its not necessary to save it out. Bypassing Vdub and going Straight to TMPGEnc is not recommended, as you may have a audio problem that needs to be saved before use.
Most people save the WAV uncompressed at 44.1Khz without caring if its needed or not, since it don't take very long to do anyway, and does speed up the encoding in TMPGEnc as the audio does not need to be decompressed before conversion.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
Does TMPGEnc DVD Source Creator 4 convert Divx(Avi) with audio?
By Plarocks in forum Authoring (DVD)Replies: 9Last Post: 10th Sep 2007, 17:11
