I have ripped and burned Kate and Leapold successfully. However, when the movie nears the end last 30-45 minutes the sound doesn't match up any more (not off by much). The sound needs to be delayed a half a second give-or-take.
How can I do this? Is there something that will let me delay the sound? If so does it just load the VOB and make the changes? Or do I have to go back further to the .ac3 file? I was hoping I could just play the VOBs until I find the one where the sound is out-of-sync and correct that one VOB.
Thanks in advance!!
Skin
Ok I found out a little more info if this helps?? The first VOB sound plays fine (in-sync). The 2nd VOB starts ok but soon after starts gaining on the video (meaning sound before lip movement
Let me know what I need to do to correct this......which I hope doesn't require another ReMpeg2 run
Thanks -
OK does anyone know how to adjust the sound???
Or am I gonna have to start over? DOH! -
I played around with this problem for a while. This problem pops up with a few dvds and i think its a seemless branching issue. The only thing that worked for me was posted on the doom9 forum. Go there and search kate and leopold. Go to the thread named "angle issues with kate+leopold". Check out what THCM posted about using Ifo-Edit to eliminate the seemless branching problems. You have to eliminate certain vob id's depending on the angle you would like to process. It worked for me. The only thing that worked for me.
Doom9 forum is here:
http://forum.doom9.net/
Like I said search "kate and leopold" to get to the thread.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26 -
Recode Audio Sync Problem
By bdey01 in forum DVD RippingReplies: 0Last Post: 8th Jun 2007, 14:19
