Hello, I am capturing with an AIW Radeon card with ATI MMC 7.6. I capture at 480x480 at 2.4Mbps. when I do this and burn it to a vcd the picture is watchable but it has little boxes thoughout the picture. It would be painful to watch this for a half hour. Any ideas. Thanks
Cary Sauer
P4 1.6
256MB
40Gig HD
Are you capturing straight to VCD mpeg. For the best quality capture to AVI first using huffy compression. Then use TMPGEnc to convert your captured AVI to a VCD compliant MPEG.
This method requires a lot of temporary hard drive space for the AVI file, but you will achieve a much better looking VCD.
Craig -
Make sure you use IBBP and set motion estimation to 100% when you create your custom preset in MMC (P=4, B=2).
If you do I-frame only 480x480 @ 2.4Mbps it will look like crap no matter what encoder you're using.
Better yet, download the MMC 7.7 upgrade. It has a preset for compliant SVCD captures. -
Thanks. I downloaded 7.7 and captured with the SVCD setup but the picture when I burned it was fine in the scenes with little movement but bad (blocky and at times in slow motion) when there was more movement. Any ideas. Thanks. My DVD player is a JVC 500BK and should work fine. Thank you.
Cary
Tbc makes bad picture worse
By mammo1789 in forum RestorationReplies: 3Last Post: 19th Oct 2011, 20:46 -
BetaMax plays fine for a while then bad picture
By LSchafroth in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2010, 21:31 -
Philips dvr 3506/37 - bad picture
By Psco2007 in forum Newbie / General discussionsReplies: 10Last Post: 1st Jun 2010, 19:19 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Background picture looks bad DVD authored with GUI for dvdauthor
By stars in forum Authoring (DVD)Replies: 10Last Post: 10th Feb 2009, 04:32
