I have a major problem.
Movie (Xmen), format AVI.
With virtualdub i merged subtitles with it, then i use "frame server" and
save the file as xmen.vdr
Then go to TMPGEnc en load the saved file (xmen.vdr) in video-source.
The following error-messages apears : "can not open, or unsupported"
I followd the tips on this site (EDIT) but it didn't work.
I Use virtualDub (version 1.4.10) en TMPGEnc (version 2.56.39.143)
Annyone some suggestions ??![]()
Results 1 to 9 of 9
Did you download the TMPGEnc plugin, and did you activate it?
The Dutchman -
Go to the download section of the TMPGEnc site. There are two files to download. 1= the TMPGEnc program, 2= the TMPGEnc plugin. Open (after download) the plugin in the same folder as TMPGEnc is stored, and execute it; this should activate the plugin.............
The Dutchman -
i put the plugin in there but i receive "canot open or unsuported"
whats hapenning? -
Which filter are you using in Virtual dub? Is there no preview option? This way you can check if the subtitles are correctly displayed
The Dutchman -
its ok now the subtitles was in incorrect extension, but now is ok, thanks man
subtitles with TMPGEnc Dvd Author 3
By yoshiboy37 in forum Authoring (DVD)Replies: 3Last Post: 26th Dec 2014, 05:31 -
TMPGEnc Authoring Works 4 Subtitles
By Sakuya in forum Authoring (DVD)Replies: 4Last Post: 15th Apr 2011, 03:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Permanent subtitles with TMPGEnc Xpress 4.0
By b00h in forum EditingReplies: 2Last Post: 18th Dec 2007, 15:43 -
TMPGenc 3 - subtitles for dvd help
By cajmere in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 07:28
