  1. I am trying to load an .avi file in TMPGEnc and it reads:
    'File "C:\Project\186.avi" can not open, or unsupported'
    I've downloaded all the codecs, as well as try to ascend the priority of the DirectShow Filter. All these attempts to no avail. I would like to know if there's anyway I can fix this problem, or if there are any other strategies. I'm not sure if this is the problem but the file's fps is 14.985
  2. Banned
    Jun 2001
    UK
    Provided the movie is not a fake You have not installed all the codec's. Try the Nimo Codec pack.
  3. Originally Posted by KingJohn
    I've already installed the Nimo Codec Pack, thus it still doesn't accept. And I'm sure the movie is not fake, since I can play it easily with Windows Media Player.
  4. I have the SAME exact problem
    windows xp pro
    avi movies work fine in Windows Media Player, but I am unable to convert them
    tried about 4-5 movies
    anyone have any other ideas
    i also installed the NIMO codec
    thanks in advance
  5. Banned
    Jun 2001
    UK
    There is nothing that wont load into TMPGEnc, however try loading it into Vdub, see if it tells you something about the movie.
    Try file > File information at leased find out what type of movie you have
  6. this is what is says about the movie from virtual dub
    frame size 352x288
    12,500 fps
    divx 5.01x codec compressor
    number of key frames 330
    audio 24000 HZ
    channels 2 stereo
    sample precision 0 bit
    fraunhoffer IIS MGEG LAYER 3 CODEC
    anything catch your eye here that may be causing the problem
  7. Banned
    Jun 2001
    UK
    It is diffrent from most The only thing that stands out is the DivX 5.01, last Nimo release does not have this.
    You can download the DivX 5 from here http://www.divx.com/
    Latest version: 5.0 Alpha 2 (released 2002-06-13). I guess this is a spywear vertion, so you need to look around for a hacked DivX Pro 5.0.2
    Divx 4.12 Build 307 (Project Mayo) was the last release before this became comercial, older DivX 5 movies could be played with it but not converted.
