I was wodnering if DVD burners/writers can copy movies that you rent and then put it on a blank DVD disk? casue that is the only reason i would get one..... and if the process is long and hard or if it is simple..
Look to your left. How to...DVD rip. Click that, then scroll down to the DVD to DVD section
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
if your movie comes in at under 4.7G you should be able to rip'n'burn to DVD-r. If it is over that then you have a DVD-9 (dual layered) DVD and you will have to chop something out, like special features, soundtracks etc. Worst case is you will have to re-encode the video to a lower bitrate to fit it on a DVD-r.
As most movies these days weigh in at around 6G you will have to do some chopping and re-author the DVD....
.....or you could save your money and buy the movies you want...
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 14:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
