I am attempting to capture video via my DVC 200. When I capture as an MPEG2 file - when the file gets to about 3.6GB it automatically stops and starts another file. How can I get it to just make one big file. Is it my software? Or is this just a limitation I'm stuck with? I am using WIN Xp and NTFS.
DCS 200
Results 1 to 11 of 11
Well, dude, WHAT is your software? It is your software in any case. It was not designed for NT, apparently. It sucketh!
I agree, you are using not using windows 2000/xp, or your applicaton was designed for windows 95,98,me and its capping before the 4Gb limit of that os.
Steve -
Not familiar with your software, but many have a setting for maximum file size, check for this buried in some settings menu and set it to maximum drive space to use. Also, check the manufacturer's website for an upgrade or patch.
Sorry... software is Moviestar 5. Could someone please refer me to a piece of software that will allow me to capture files larger than 4GB (That won't automatically start a new file).
DCS 200 -
If you read the first post DCS 200 states that he is using win xp with NTFS filesystem.
I see you just did.
Craig -
I tried to use Video Studio 4 with my DVC1 and it crashed like a flying pig. Heck, I think it would have run faster if I had simply chunked it across the room. Now, I do remember that in DVC1 with an older version of MovieStar you could specify file size. That might be the culprit, but it could also be a bug.
Incidentily, MovieStar 5 was written specifically to run with XP and 2000. Few new hardware products are not... hmmm... This is a poser.
Sod out... -
I run XP pro with ulead video studio 5, I have never had it crash, and it has never dropped a single frame during dv transfer.
Craig -
@craigtucker
Yeah, with DV. Were talking MPEG-1 & 2 caps through it. I got it to cap DV just fine. Using my DVC1 (which is a MPEG-1 capturer through the USB port) was entirely different story. So that option is out unless Ulead AND Dazzle colaborated on this to cap using VS5... Anywhoo, glad that you are able to cap DV using VS5.I run XP pro with ulead video studio 5, I have never had it crash, and it has never dropped a single frame during dv transfer.
Sod out...
Easycap usb large capture files
By visionman in forum Capturing and VCRReplies: 5Last Post: 4th May 2010, 18:23 -
Help with large TS file
By mejallen in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2010, 20:44 -
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 13:47 -
large iso file
By fabpozzi in forum Authoring (DVD)Replies: 10Last Post: 13th Dec 2008, 13:10 -
Avi file too large for CD
By hitmanhill in forum Newbie / General discussionsReplies: 17Last Post: 22nd Jan 2008, 15:19
