I'm new to this, but I have a couple of DVD movies that are a bit to big. I edited them both, the size now looks small enough, but when I try to burn them, it still shows they are to big. In fact, the same size as before. Is there something I'm missing? The size of the converted file is smaller, but when trying to burn them, they still say to big!
what are u trying to accomplish?how big are they really?
which ripper are u using?just questionz.......... -
I'm using virtualDub, to compress the movie thats to big to fit on a DVD. After converting it, in Windows Explorer, it shows the converted file, as smaller. 665.824 KB. Before converting, it shows the size as 716.764 KB. But when trying to burn it to DVD, it still shows it as to big. Just as big as it was before. Both files play ok, but the smaller converted one will still not fit the DVD. It still show it as the same number of bytes to big.
I'm not sure how to explain it, in any other way. What could be the problem?
Both before, and after conversion it shows 6.69 GB oversize!
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 14:19 -
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 15:04 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 09:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 05:14
