can someone please help when i download movies from cervers on AOL the emails come in files of 55 or so for each cd. the problem is i can spend 4 or more hrs downloading each file get a bin and cue then try to burn the cue which is the format on nero for burning images and get an error stating "cannot write compilation in TAO with this recorder" i even went to pref and enabled overburn still no help. the total of file is only 798 mg the cdr is 700 but that shouldnt be a problem ive overburned before now sometimes i can burn a movie and i dont get this error i burned a SVCD version of monsterball with no problem and this particular movie is sum of all fears in SVCD it wont work and im really pissed spending an entire day and this is the result. if someone can help i would really appreciate this. i was wondering if amt of files plays a part in this ? if any are missing etc?
the program you mention ordax how does it work? you man i download the 70 files and it takes over from there? dont i have to burn it with some program? also how much is it?
Try using a ISO buster to extract the .dat file, then you can make a VCD up with Nero in the normal way.
WinISO.v5.3 is good
With Nero 7 Ultra, why are imported dvd files so big?
By wisny in forum EditingReplies: 13Last Post: 13th Mar 2011, 07:38 -
too big when burning with nero
By chief-1 in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2010, 21:21 -
Big Problem
By k_pratl54 in forum DVD RippingReplies: 7Last Post: 9th Mar 2010, 20:37 -
big problem with soundmax
By marlo in forum AudioReplies: 6Last Post: 23rd Jan 2010, 03:40 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 19:41
