i have a dvd that is not region 1 and cannot figure out how to rip that into vcd format. what steps do i follow? i have followed the newbie guide to rip region 1 dvds with no problems. also how do i simply duplicate an original vcd to create a backup of the that disc? thank you
joe
Which particular guide did you use? What region do you want to convert?Generally the procedures are the same unless the the format is NTSC(film). Region 2 is almost always progressive rather than interlaced. The important thing is to choose the VCD template which fits the framerate of the original.
As to copying VCD I always use CDRWin's *backup disc* option. Nero's disc image option should also be OK. -
thank you for the info on copying. i was using the newbie dvd to vcd guide by sefy. the disc was the jungle book but samrtripper wasn't identifying it and i couldn't figure out what region it was. is there an opion on vcdeasy to copy a vcd? i don't have new or cdrwin yet. or is there an inexpensive place to buy either nero or cdrwin? nero seems pretty expensive. thanks again.
joe -
Some DVD drives are locked to a particular region - maybe this is the problem? Smartripper is unlikely to be the problem.
As to Nero and CDRWin, if you look around both can be obtained for next to nothing. 8) However, CDRWin will write at 1X even in evaluation mode, if I remember correctly. -
Which DVD Drive do you have ? as mentioned before me, your drive might have gotten locked and won't let you access some regions anymore, let me know which drive you have in email, and i'll send you a firmware for it if has one.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Ripping Region 1 disc to burn Region 2/Free ?
By Alan Rouge in forum DVD RippingReplies: 7Last Post: 28th Sep 2010, 21:09 -
Absolutely clueless on copying/ripping DVD
By app1mpo in forum DVD RippingReplies: 4Last Post: 28th Sep 2010, 16:01 -
DVD Region 1 Hack Needed!
By poisonivy4 in forum DVD RippingReplies: 2Last Post: 14th Jun 2010, 10:43 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 00:30 -
Samsung DVD-P370 region free needed
By Master78 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th May 2007, 21:27
