Hi
Downloaded Royal Tenenbaums DIVX approx size 700mb. Using the new tmpgenc 2.56 I used the wizard at the start and loaded in the standard NTSC template. I make no changes to it but the estimated file size is 3.5 GB!! I encoded 1% and it was 33MB. I have done a few conversions with previous versions of TMPGenc and a 700mb DIVX usually comes to about 1.5-2gb at the most. Surely this cant be right, can it?
Any help much appreciated.
Richard
Which standard NTSC template? NTSC VCD? NTSC SVCD?
RTB is 109 minutes, and would run ~1090MB in VCD format. In SVCD it could vary, but might be as much as ~3GB at 2524/224 CBRAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Originally Posted by rbarr77
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
H.264 output file size too big vs WMV
By bijoythulas in forum Video ConversionReplies: 5Last Post: 29th Sep 2008, 21:21 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 19:48 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 17:53
