  1. hello (sorry babelfish English)
    I look a possibility up a videoTRACK for loopen which programs or possibilities give it this to implement
    thanks
    May 2001
    London, UK - Bonn, Germany
    If you are talking about playing a VCD on your standalone DVD Player, you should try to "repeat all/chapter/title" facility - which would be the easiest solution.
  3. hello and thanks for its response
    which they mean with " repeat all/chapter/title "?????
    I would like on my home dvd more player intro (TRACK 2 TRACS 1 data a TRACK is there) automatically so long loopen to leave to I TRACK NEXT on mine ir controller pressed how is this possible???? functions only with more vcdimager (vcd2xml) must I the scriptsprache " XML " absolutely use or gives it a program with which I over a GUI (looping) to make can I would like none chapters and so to insert only the first video TRACK is itself automatich after he is terminated to repeat
    thanks (sorry this is babelfish english. very bad ;( )
    May 2001
    Unfortunately, I didn't quite understand what you wanted. I presume from your email address and a few wordings used, that you are German. Schick mir ein email mit Deinen Fragen, da man sich hier nur auf englisch unterhalten darf! Ich versuche sie dann zu beantworten.
    <font size=-1>[ This Message was edited by: aldus4 on 2001-08-07 07:49:31 ]</font>
