ok ive done two good copys with spruce up dvd but i cant seem to do any more whatever dvd i rip (i have the full version of spruceup) i can load the .m2v file and .ac3 file in ok but when i go to play movie (step 2) it comes up with ..... spruceup heas caused error in GPI.DLL spruce up will now close . .... so it did and the preview wont work with any dvd now but it will play the menu up untill i click the play button..... Problem 2
if i ignore that problem and cary on to make a disk image to burn in prassi primo it does the job but when i go to burn in prassi it gives a error at the start of the burn and terminates any 1 got any ideas
o yeh if i make a title set and burn it with nero i can do it as a iso but if i select dvd video it wont let the vobs be moved to the VIDEO_TS file dunno whats happening must be spruce up i guess any ideas any 1
o ye im trying to burn a dvd
...when i go to burn in prassi it gives a error at the start of the burn...
...if i select dvd video it wont let the vobs be moved to the VIDEO_TS file...
Avisynth - correct defects caused by sharp
By byme in forum EditingReplies: 5Last Post: 3rd Feb 2011, 12:59 -
MeGUI - DAR error caused by latest update?
By Tiernan in forum Video ConversionReplies: 0Last Post: 17th Jan 2010, 19:24 -
cropping interlaced YV12 video caused chroma error
By dphirschler in forum EditingReplies: 2Last Post: 3rd Dec 2009, 10:07 -
Why upgrade RAM caused BSOD ?
By pchan in forum ComputerReplies: 3Last Post: 12th Aug 2008, 06:33 -
WINDOWBOXING... Caused by DVD Player / Plasma...???
By Lathe in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2007, 18:43
