I downloaded a movie in divx format. When I try to watch it, the video hangs around 15 min into it while the audio continues. I can forward past that point and the movie plays fine. I've tried using divfix to check for errors and rebuilding the index but to no avail. I've thought about trying to go ahead and encoding the movie to see if this problem carries over. Any ideas? Thanks.
Load the AVI into Vdub
Select Video > Scan Video stream for errors
Video > Direct stream Copy
Audio > Direct stream copy
SAVE AVI (Save movie2.avi)
If Vdub fails to scan, this is a know problem, download "vdub-mp3-freeze.exe" instead, this is hacked version of Vdub and makes a list of bad frames at c:\badframes.log You can then use this log to delete the bad frames (Start with the highest number first)
Notes
vdub-mp3-freeze.exe is the best for finding bad frames, By removing the highest numbers first, you don’t need to scan more than once.
1840 (Delete third)
1841
1842
72345 (Delete Second)
72346
72347
72348
124589 (Delete first)
124599
124600 -
another thing you could do is download divx anti-freeze... you can get it from doom9.net in the downloads section under codecs..
Fairuse Wizard 2.8 Hangs
By herzeleid in forum DVD RippingReplies: 5Last Post: 14th Sep 2013, 07:53 -
Chapters to DivX Movie ?
By PowerFalcon in forum Video ConversionReplies: 6Last Post: 3rd Nov 2011, 19:15 -
DIVX Movie Converting?
By RecoveryTTA in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2010, 21:22 -
DivX Movie Playing
By ghforlife in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 11:38 -
SVCD2DVD Hangs
By chucky246 in forum SVCD2DVD & VOB2MPGReplies: 31Last Post: 3rd Jul 2007, 06:28
