  1. HI, I have just started using KAZAA. I have downloaded some movies. THey play fine on my computer using DIVX Player 2.0. I am now trying to make them into VCD. I have the program TMPG encoder to make the AVI to MPEG format. I have used it before on some things I downloaded off of an FTP site. But when I try to open the source in the TMPG program it says that it can not be opened or supported. Any Idea's what to do next. I have tried different programs but none will work.
    Kevin
  2. Then that file isn't a supported mpeg...you will have to reencode that file to mpeg-1 format.
  3. How would I go about doing that, what software do I need?
    Kevin
  4. Banned
    Jun 2001
    UK
    Kevin
    Your probably missing a DivX codec, Install the Nimo codec pack, it has them all 8)
