  1. Is this possible? I'm trying to rip a .WAV from a couple DiVX movies, but Virtualdub can't do it for some reason or another. Is there another program to rip (AC3) audio from DiVX movies? I'm gonna convert the AC3 to WAV afterwards (making VCDs from DiVX), but can someone help me out please?
  2. Graphedit will do it. Although I don't have the exact directions. Do a search on the forum for graphedit & it will be in there somewhere.
    Good Luck.
  3. What you need is Virtualdub_AC3.. this will allow you you extract the raw AC3 form a Divx... Audio>direct stream copy // File>save WAV...
    You can then convert to WAV with Headac3e
