I have recently dl 2 movies that work great on my computer, but make the screen roll and are in black and white on my tv. I have dl many movies and all have worked well. I am in America and have burnt NTSC.
I tried using virtualdub to see my source but get an error message saying that it can't determine file type.
I tried using TMPGenc to look at the .mpg file but it says that the file type is not supported.
I tried loading into myflix, but it tells me that mpeg-2 isn't supported.
I guess I am just confused as to why these two movies are the only ones out of the many I have dl that do this. Any help would be greatly appreciated.
The decompressor needed to view the movie is missing, nip out and buy it
whoshhhhhhh... got it already ?
The decompressors is commonly know as a codec, you can download the popular like DivX MPEG-4 V2,3,4 or DivX 3.11 Alpha, but save some time and install them all with the Nimo codec pack -
I already have the codecs on my computer. The problem lies in watching it on my home theater after I burn to vcd or svcd. They work GREAT on the computer but not on the home theater.....
Woops, did you make a PAL by mistake then ?
This tells me you dont have ALL the codecs, or its a fake...I tried using virtualdub to see my source but get an error message saying that it can't determine file type.
I tried using TMPGenc to look at the .mpg file but it says that the file type is not supported. -
No, I didn't burn PAL. I tried it again and still got the same results. It happened on all of the discs for the movie.
I wonder, does it matter if the source file was PAL? I really don't know what to do except re-dl the entire thing.
It has happened again on my copy of Unfaithful disc-2. All of these came from the SVCD.Centropy. file types.
This has me really baffled. -
Unfaithful, Listed below are the correct file sizes for verified files of that movie. Conversion from PAL to NTSC would not cause any problems, I do it all the time, and the other way around.
Have you scanned it with Vdub for junk frames, before conversion. Is the .mpeg fine before burn and 100% compliant (VCD template)
1 - 105,690 KB
2 - 106,538 KB
3 - 106,538 KB
sig2dat://|File:%20[tmd]%20Unfaithful.ts.(1of3).avi|Length:%20108226560%20 Bytes,%20105690KB|UUHash:%20=TQ8PNwO0A4qkv6NwoE+Vg KZte98=|File:%20Unfaithful%20(2of%203).avi|Length: %20109127680%20Bytes,%20106570KB|UUHash:=FluYFZu1d CAcgXji7rjtsicm9xQ=|File:%20unfaithful%20-%203%20of%203.avi|Length:%20109094912%20Bytes,%201 06538KB|UUHash:=nA6+0Zs5m+hbf9+4tInZB9c61a0=|/
playback problem
By winston879 in forum Software PlayingReplies: 2Last Post: 14th Mar 2011, 15:33 -
Video playback problem
By magiccastle in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2010, 07:07 -
mkv playback problem
By discohue in forum Software PlayingReplies: 1Last Post: 26th Nov 2010, 13:31 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
playback problem
By stigslim in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Aug 2007, 18:19
