Hi i saw the registry update you had for the wintv pvr 250 on your website and i would like to add those to my registry so i can take advantage of those profiles. My question is how do i add those to the registry. I am using winxp if it makes a difference. Also since you seem to know a lot about the wintv pvr 250 i was wondering if you could give me any advice on capturing. I want to capture tv shows such as seinfeld or south park and eventually convert them to divx probably. What capture settings would i use in the program. All those difference options such as vcd and svcd have me confused. Thanks for your help. -Rob
Results 1 to 1 of 1
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
