Hi!
I use Pinnacle Studio DV plus to capture video from a digital video recorder. Then i export the movie to an “SVCD-Compatible” MPEG-file. Then i use Nero Burning Rom to make an SVCD that i play in my standalone dvd-player.
The result is not good. Especialy movies taken outdoors. Persons and objects that are still is fairly sharp but when someone moves a rough compression (big pixels) is shown. The movie is just as bad if i look at it directly on the computer.
Movies taken indoors is much better.
Wath can be wrong? What should i do?
Please Help!
Offhand, I'd say the problem is that you're using what's arguably the worst MPEG compressor in the world---Nero.
Use TMPG, or even better, CCE. -
Nero is a superb burn app, but encode with TMPGEnc.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Henrik, The problem is with the pinnacle software. Once you have edited the file, save it as an AVI rather than MPG. As it`ll save in in DV format, you won`t enormous amounts of disk space. Then just encode the file in TMPGEnc using the SVCD template.
My mistake... I thought he was *encoding* with Nero.
Yeah, the guys above me are right. -
Hi!
Thanks for your advice. I tried to save the file in AVI-format from Studio and then encode it in TMPG and burn it with Nero. But i still get crapy results. Any other ideas?
Grateful for help - Henrik
Quality problems on Adobe Premiere Elements 9
By inimitable in forum Newbie / General discussionsReplies: 1Last Post: 28th Jun 2011, 05:56 -
quality problems after conversion
By blubot in forum Video ConversionReplies: 16Last Post: 17th Jun 2008, 10:08 -
AVI to DVD quality problems
By Stetsondolly in forum Video ConversionReplies: 20Last Post: 11th Feb 2008, 20:23 -
Camcorder-PC quality problems
By Brazil-Ben in forum Capturing and VCRReplies: 2Last Post: 5th Oct 2007, 17:45 -
Problems with Capture Quality
By drxpsp9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Jul 2007, 22:53
