  1. I've been trying to use DVD2AVI frameserving, I've done exactly everything written in the guides but it never works, when I load the d2v file in TMPGEnc it says that the file cannot open or unsupported, also, when I'm trying to open the file in the VFAPI converter it just pops up a message like this "???? filename.d2v ??????". Can someone please help me?
  2. see below and go down to the section about changing
    VFAPI priority setting.. this seems to be a popular problem
    http://www.vcdhelp.com/tmpgenc.htm#problems
    ALSO.. make sure you have downloaded, unzipped and installed the
    VFAPI files into your tmpgenc directory (each version of
    tmpgenc has it's own 2nd zip with these files)
  3. OK, I installed the correct VFAPI, installed MPEG-2 codec, installed the m2v.vfp for TMPGEnc and still can't open d2v files at all. Anything helpfull?
    May 2002
    Rainy City, England
    Change the VFAPI plugin priority setting as suggested. A good one to start with is DVD2AVI Project file plugin. 8)
  5. and if that does not work.. kill tmpgenc and reinstall a new copy
    from the net (maybe a new copy of dv2avi too)
