i am using tmpgenc to convert some film and want to reduce the blockiness in the film in the settings menu does the value need to up or down to sharpen the picture and how much difference does the value make i.e doe i need to change it dramatically change the effect![]()
To reduce blockiness you can enable Soften Block Noise under settings> Quantize matrix. or increase the overall bitrate under settings>video>rate control mode _but_ keep in mind this last trick may make your vcd non compliant.
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 15:51 -
Speaking of noise reduction, what is this?
By takearushfan in forum RestorationReplies: 11Last Post: 5th May 2010, 21:14 -
Any Suggestions for Noise Reduction Software
By blaqlion22 in forum AudioReplies: 13Last Post: 16th Jun 2009, 07:08 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 06:23 -
Video Noise Reduction ----> H E L P
By wxyz in forum DVD RippingReplies: 14Last Post: 21st Jun 2007, 19:22
