hi ive tried to encode from hell using tmp but says audio no supported
si i used virtual dub to extract audio but that cant do it either .
anyone have any ideas how to sort this or another prog i can use to extract the audio![]()
You have an audio codec missing, download and install Nimo Codec pack... Sigh
I'm not really clear on the "from hell can't encode" but when virtualdub rejects an avi I do one of the following:
If VirtualDub rejects the avi I do this for Ogg audio(There are probably alot of reasons for an avi to be rejected by VirtualDub but the only ones I have personally experienced is OGG and ac3 Audio)
Tools needed: GRAPHEDIT / LATEST OGGDS filter pack.
http://forum.vcdhelp.com/userguides/89139.php
for ac3 audio I use VirtualDub to extract the ac3 using direct stream copy-save wav -then rename the file from .wav to *.ac3 - then use ac3Tool to convert the .ac3 to .wav.
For the freeware check here:
http://www.vcdhelp.com/tools.htm
hope this helps -
i have encoded this onto vcd
as above i used virtual dub to extract wav from avi but i then used headac3e to convert from ac3 to wav. -
Originally Posted by willmcmanus
When loading into Vdub, if the AVI contains the AC3 codec, you will get a warning, saving out the audio converted to uncompressed WAV will then cure the problem with TMPGENC.
For some reason, I have seen posts saying people have to save the WAV using streaming, which later has to be converted. I have no problem in using Vdub to save the WAV converted to 44.1Khz uncompressed. I can only think that either the new Nimo has something different or I have some other codec installed for AC3 conversions.
How to encode audio to different fps?
By mrjust in forum Newbie / General discussionsReplies: 9Last Post: 16th Mar 2010, 21:07 -
WMM crashes everytime I import audio and I'm PISSED AS HELL
By Nintendo Fan in forum EditingReplies: 3Last Post: 23rd Oct 2008, 15:46 -
Cannot Encode, Audio Error
By kidcash in forum Video ConversionReplies: 4Last Post: 19th May 2008, 02:18 -
Trim audio without re-encode
By pchan in forum AudioReplies: 3Last Post: 17th Sep 2007, 08:29 -
Encode to audio with VBR?
By GangstaRap in forum Video ConversionReplies: 2Last Post: 27th May 2007, 08:56
