  1. I have downloaded a movie and it is a WMV file. Is this usable nothing seems to find it in TMPGE and I want to convert it to SVCD.. Please help
  2. Anonymous
    Guest
    Try Virtual Dub ver. 1.3 OR Graphedit. There is an excellent guide on
    here from a user named kenetik on using Graphedit. Just do a search
    for author - kenetik and this may help you out.
    Goodluck
  3. Best way of encoding I have found is to use TMPGEnc. Just open the wmv file by using file open in TMPGEnc and selecting all files option. You can then select the WMV file and it will encode the file to (S)VCD with generally no problems.
  4. i have a WMV/ASF file that has a problem. when i load it into tmpgenc it only recognises video stream and not audio so when i encode mpeg their is no sound !?!
    anyone know how to extract asf to WAV and then mux asf and WAV together in tmpgenc?
    ive tried Virtualdub v1.3 but it wont open the asf. also tryed blade media pro. will grafedit do it? if so how?
    thanks.
    Andy 8)
  5. Anonymous
    Guest
    I had tried this with my ever so troublesome asf file but the est. time
    would increase till the encoding session eventually locked up. I had to
    use Windows Media Encoder to re-encode it so that GraphEdit would
    not crap out on me near the middle of the process.
    I would try GraphEdit first as this would give you a workable file. If it
    craps out then re-encode with Windows Media Encoder, then GraphEdit.
    After that you can convert it to avi with VirtaulDub and then from there
    I can't help as this is where I am at in the process. Actually, I am at
    the point of "PULLING MY HAIR OUT" due to video/audio sync
    problems. But, I am patient and if any one of the ideas I am following
    works then I will:
    A) Know what to do if this happens again
    B) Help others with similar problems.
