I use TMPGEnc, and when it reach around 21%, it say this error: Illegal floating decimal point calculation order.
Can you tell me how i can prevent that and continue to burn my DVD?
Go into Tmpeg's "enviramental" settings and make sure it's set correctly for the CPU you are using.
i get the same error in tmpgenc and in virtual dub i get the error
"Internal error: MMX state left on: T:\projects\VirtualDub_old\main\VideoSource.cpp:11 01 "
at the same point in the movie if i try to scan for bad frames
i'm using a P4 1.7Ghz so i assume its ok to have all the boxes checked in the enviornmental settings cpu section in tmpgenc
if you know any different or have any other suggestion please share,
thanks
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 05:33 -
error message
By geerunner in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Oct 2010, 20:58 -
Error message! Help!
By XAPHSNYC in forum MacReplies: 6Last Post: 8th Feb 2010, 14:05 -
sent message is in outbox?
By jjbtnc in forum FeedbackReplies: 3Last Post: 29th Dec 2008, 07:32 -
Error Message
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Jul 2007, 12:45
