ok, this has been confusing me for the past couple of hours. I done a vcd of rat race and the first part last 1hr 6mins which is 66mins but when I put it through nero to burn the minutes when upto 90mins how come this has happend??
Can you offer any more specifics as to the resolution and bitrate of your source file?
Oh, codec and frame rate might also be informative.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
yeah, sorry.
used the tempgenc standard ntsc Film template here are the settings:
Video-CD NTSC Film
MPEG-1 352x240
23.976fps
CBR 1600kbps
Layer-2 44100Hz 224kbps -
I re-encoded the film to the default bitrate and it seems to be within the 80 mins mark.
Originally Posted by andybno1
Video-CD NTSC (MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 224kbps)
Dont let nero re-encode, it will make a mess. -
thanx king john but I had already encoded by the time I got your message. How come if the bitrate is bigger than the default rate, it makes the film in nero seem like its over 90min?
mpg file won't play on PS3 after running mkv2vob
By drthundr in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2011, 12:55 -
How can I shrink down the running time of an audio file?
By darkzero297 in forum AudioReplies: 3Last Post: 16th May 2009, 12:07 -
Total running time
By mrcoolekin in forum Authoring (DVD)Replies: 26Last Post: 15th May 2009, 01:38 -
Maximum running time
By biged670 in forum Newbie / General discussionsReplies: 4Last Post: 17th Feb 2009, 17:39 -
DGPulldown and running time?
By ecc in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:23
