This is my first time on this site and I think I have looked through every forum there is but I just can't seem to find out how to back up a DVD with a Mac computer. I have a PowerMac Dual G4 1Ghz with the Apple SuperDrive. I have one DVD (The Crow) that has a scratch in it and I would like to try to fix it by backing it up onto a DVD-R. If anyone out there can help me, it would be greatly appreciated.
Nick
Sydeshow Productions
Goes something like this.
If your DVD is under 4.3 GB in size you can just use DVDExtractor 0.9b to save an image of the dvd on your HD. When its done you simply mount the image in toast and burn.
- u can get DVDExtractor off www.opuscc.com
If its slightly over 4.3 GB (say up to 5 GB roughly) then you can burn the movie only, no extras, special features etc. Do this by demuxing the main track of the dvd in DVDExtractor and then use DVD Studio Pro to create a new project and recompile the .m2v and .ac3 streams back into a dvd format (VIDEO_TS folder)
then just burn that folder to dvd (as a dvd project of course
If its way over as a lot are these days then you have to use IFOEdit on a pc (or virtual pc if u got it) and split the dvd into 2. Don;t know how to do that yet though..
Hope this helps...
greenmynci
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43 -
Best dvd software for mac. os x
By fpunky in forum Newbie / General discussionsReplies: 9Last Post: 29th Jun 2012, 22:09 -
Need help backing up dvd on a mac
By pibrew in forum MacReplies: 1Last Post: 23rd Aug 2011, 17:22 -
Toast vs. iMovie/iDVD which is better for Mac?
By HowardNeedsHelp in forum MacReplies: 13Last Post: 2nd Sep 2009, 11:42 -
Menu button selection order in iDVD vs. Toast 10 DVDs for MAC
By HowardNeedsHelp in forum MacReplies: 0Last Post: 29th Aug 2009, 12:06
