I am using winproducer/wincoder v2.0 and for some reason it doesnt let me grab pal dvd in full or half only ntsc in full and half..
If i select the profiles from the main screen it allows me to select pal full, but when I click on the wdm capture and then click on the profiles on the new capture box it only allows me to select pal dvd 1/4..
However if i do the opposite and select NTSC it then allows me to do all available size of dvd..
It just seems to have problems with the Pal side of things
Has anyone any ideas??
Cheers
Sean
Results 1 to 1 of 1
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Feb 2009, 12:55 -
DUP 5990/37 - Pal & NTSC all the time?
By mraroid in forum DVD & Blu-ray PlayersReplies: 18Last Post: 12th Dec 2008, 12:56 -
Portable NTSC & PAL TV?
By Disco Makberto in forum Portable VideoReplies: 12Last Post: 14th Nov 2007, 23:31 -
Viewing quality between PAL & NTSC ??
By VEBouto in forum Newbie / General discussionsReplies: 24Last Post: 22nd Oct 2007, 13:50
