hi can someone recomend a software program for playstation games on pc other than bleem?seems bleem wont play some newer playstation 1 games
You would want to get Connectix Virtual Game Station. It works great for me. I could send you it or I'm sure you could easily find it on Kazaa like I did by doing a search on playstation or emulator or even Connectix.
If you want me to send it to you (Its only 710k, very small) you can contact me on any IM as dragonsi (Yahoo, MSN, ICQ) dragonsi2 on aim.
I'm looking for a PS2 working emulator. I currently have one called eKaf, but no roms only the real PS2 games and nothing happens, or should I say I don't know what type of file I'm supposed to load up on my PS2 disc since there are no "exe" files on it. -
Actually there's an even better emulator out for the psx.... it's called EpsxE at www.epsxe.com. It's the best emulator for the psx (yes better than bleem or VGS). To learn more about emulators for psx and for other consoles like the saturn, gameboy, n64, etc, go to www.ngemu.com
I got like around 65 emulators for every system but since I just got it on a cd don't know what to do? I can't get bleem to work must be that bleem is an xp hater and i got a ps2 emulator but i need to download roms dam i hate downloading i have a cable modem and thats al i do i want time for me. Does anybody know if ther is an emulator that plays ps2 games directly from a disk?? i would reward them greatly with any of the emulators that i got or if they want movies i got you or at least software. (aim screen name wickedassimage)
or msn Im me (imageone69@msn.com) thanks !
EvErY0nEs A HaTeR BuT mEE! -
Uhh so far as I know there aren't ANY ps2 emulators (there are like.. 2 that can play demos but that's it) it's going to be a while before they can read it off cd-roms and shit.
@Suckonthis:
So, you just got the CD full of emulators and roms also and you want to install them to play on your hard drive?
What I did for those and any other program that you want to permanantly associate with certain files is to:
1) Create a special folder for the emu and roms such as: C:\Games\Emus\Gameboy Advance\ then I put the Virtual Advance program there and all the roms (.gb, .gbc, and gba) and right click on any rom file, such as Tactics Ogre.gba and choose "Open With...", then a box will come up with a list of all programs except, of course the Virtual Advance since you haven't used it yet. So click on browse and go to C:\Games\Emus\Gameboy Advance\ and choose the .exe file. Make sure that the box saying "Always open these files with this program" IS checked. Then all you have to do is click on any .gba file and it will automatically open with Virtual Advance, as long as you don't move the .exe file out of that folder.
If you get a better emulator for Gameboy Advance games and you want to change the association later on to your new .exe file, then open up Windows Explorer, or click on "My Computer" and go to TOOLS button up top then Folder Options, then File Types. Scroll down the list of extensions to .GBA and click on Change, then browse to your new file to permanantly use for the games then.
Next, you want to be able to simply play them from your start menu without having to find all your roms in Windows Explorer? Go to Start/Settings/Taskbar and Start Menu. Then go to Advanced Tab then hit the ADD button. You can then browse for either your favorite game to add to the Start list, or use the Virtual Advance exe itself and load the roms from the program itself, and it will be on your Start/Programs Menu then.
Encoding for Playstation 3
By nerfgun in forum ffmpegX general discussionReplies: 52Last Post: 15th Mar 2010, 16:57 -
PlayStation 3 vs Philip 5990/37
By reg505 in forum Newbie / General discussionsReplies: 5Last Post: 18th Dec 2009, 09:36 -
UK Playstation 3 Question
By Anakin in forum DVD RippingReplies: 10Last Post: 30th Aug 2008, 02:43 -
Playstation 3
By Jake802 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Jun 2007, 21:57 -
How to copy Playstation 2 games
By avz10 in forum Off topicReplies: 21Last Post: 3rd Jun 2007, 09:12
