ok
ive only just started using TMPGEnc
ive downloaded a movie that is two files big and about 700MB each file
what i wanted to do was split it inot 3 discs so i would have a backup copy
i used the merge and cut option and happily cut my first disc off at about 560MB and stored it in a safe place
then i cut the remainder of the 1st file out so i could later merge it with the beggining of the 2nd file i had yet to cut
the end of the 1st file went great..only 140MB big
then when i tried to cut the beggining of the 2nd file out it would only cut about 1 minute of it out and not the 28 minutes i wanted
i am making sure the sliders are correct and doing exactly the same as with the first file but this has happened on several occasions..
it also wont let me cut the 3rd disc out(the 2nd part of the 2nd file) saying 'illegal mpeg video stream'
can anyone tell me if the 2nd file is faulty(?) in some way or what i would need to do to repair it or fix it...
i really need this on discs as my HD is getting very clogged up
any help would be great
treelo
if you are getting an error message like that then i would say that something is wrong with your file. the only thing i can think of to do is re-encode it
how do i do that mate?
im new at this kinda thing..was hoping i could just split and all would be happy..but not so
ive got the basic cutting and merging things going ok..just that error..
wondering if it was common or not -
sometimes you do get errors, iv'e had a few like that myself. as for re-encoding,
<----click the green section where it says "newbie" then find the guide that pertains to your file and follow it.
hope that helps..
Cutting MTS: splitter problem
By cheerful in forum EditingReplies: 3Last Post: 6th Jun 2012, 20:26 -
Unusual bluray format problem
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 14th May 2011, 12:50 -
Problem with fresh PC system build - unusual instability
By PartingShot in forum ComputerReplies: 24Last Post: 6th Oct 2010, 21:36 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 09:44 -
Unusual Raid Problem
By mysts in forum ComputerReplies: 6Last Post: 27th Apr 2008, 20:52
