I did search the forum for help with this topic, but i didn't find any answers that solved/applied to my problem.
Here's what happens, when i encode using the widescreen settings in TMPGEnc, i get a movie file that has widescreen, but the actual height of the picture is a little scrunched. Compared to the original DVD, the backup's picture height is a good 4 inches smaller. So the widescreen works, but the picture is scrunched, and sometimes it distorts the movie a little because the people, cars, buildings, etc... look really fat and wide (because the picture is not tall enough).
TMPGEnc Settings:
Super Video-CD - NTSC Film
Video Type: Non-interlace
Source Aspect Ratio: 16:9 525 line (NTSC)
Video Arrange Method: Full screen (keep aspect ratio)
I don't know what could be causing this, would changing the source aspect ratio to "16:9 Display" result in any different results? I'm really stumped so if anyone knows how i can fix this, please let me know.
Thanks!
Mojo
You could try center custom size. Then you can size the screen to your liken. In tmpgnc go to advance menu select the box for I belive it is called clip frame put a check in the box. then double click to open and you will see a screen. Select arrange video and then select center custom size. Now you can see your video change before your eyes when you mess with the size boxes to increase or decrease your video window.
Cool, thanks for the tip, i'll give that a try.
If anyone knows a different way, let me know!
Thanks!
Mojo -
Click on the advanced tab in TMPGEnc & make sure the source aspect ratio is set to 16:9 NTSC there also.Originally Posted by mojo2185
I checked, then i double checked, and the settings were 16:9 525 line (NTSC) throughout all TMPGEnc settings, so i don't think thats it. Thanks for the reply anyway though.
Mojo
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 11:59 -
problems importing widescreen video
By video_enthusiast07 in forum EditingReplies: 1Last Post: 10th May 2010, 02:18 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 13:22 -
Problems Exporting Widescreen 16:9
By Funky Monk in forum EditingReplies: 3Last Post: 12th Sep 2009, 11:13
