Ok i know how to make great back up copies of dvd's in svcd formatt using, smartripper, dvd2avi, tmpg and nero but what i would like to know is ....i downloaded a movie off kazaa, its in AVI formatt. How do i convert it to make it svcd?? its just when u make a svcd off an original dvd by the time you use tmpg there is 2 sepparate files video and audio, but these downloaded file are not sepparate, its just one file (the whole movie video and audio) in AVI formatt. any help would be greatly appreciated, thankyou.![]()
http://www.vcdhelp.com/divxtovcd.htm
Hope this helps.
The movies usually on Kazaa and Morpheus are in DivX format. -
Premature Enter...
I've been having problems with them recently, and I don't know what the problem is.
Good luck, and hopefully you won't get any problems... -
ty for the help if it is a divx file. Its almost done downloading but says its a .avi file is that the same as divx? if not then how do i convert it from avi to svcd?? i mean like i said know how to do it off an orignial dvd and you end up with a sep video and audio file that you combine in tmpg, but this already has video and audio combined before tmpg. If anyone downloads movies off kazaa and converts them onto svcd on a regualr basis could you please lend some help here. thankyou to all
Load the downloaded file as your video source in TMPGENC. It should pick up the audio source as being the same file. If not, load the file as the audio source also. Select the SVCD template... and encode!!!
I have downloaded a movie but it claims to need a avi extender
By dragonext in forum Video ConversionReplies: 9Last Post: 25th Sep 2011, 23:21 -
removing subtitles (foreign language) from a downloaded movie
By gizmobently in forum Newbie / General discussionsReplies: 3Last Post: 26th May 2010, 23:40 -
Downloaded movie wont open..
By bahnan in forum Newbie / General discussionsReplies: 7Last Post: 20th Jun 2009, 11:56 -
Won't play whole downloaded movie.
By amyyo9 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Dec 2008, 00:20 -
what type of file extension is a movie downloaded using BitTorrent?
By geek2330 in forum Newbie / General discussionsReplies: 9Last Post: 13th Dec 2007, 21:15
