Someone has posted some CSI TV episodes in full HDTV resolution and the result was incredible...
All posts to this individual have not resulted in an answer, so I am putting it out here.
Does anyone have an idea in terms of capping at that high a screen resolution (1920 x 1080).
Thanks...
I like people that are capturing TV programmes with an HD TV-Tuner card to comment. For the U.S. I think it is not justifiable simply because there are not enough HDTV-Channels. Maybe I'm wrong, so I will like to hear from others. We are now used to see at least 200+ Channels since Cable TV has high penetration in the U.S. Over the Air Broadcast amounts to no more than 3-5 HDTV Stations per Large U.S. City.
If your Cable Company is re-transmitting large numbers of HDTV Channels via cable then it would be a justification for HDTV capture and an HDTV, but that is not the case.
The otherway to look at it is that with an HDTV capture card you should be able to capture the best quality of Standard NTSC signal since the card has the capacity for HD.
I like to capture HDTV signals but it doesn't make sense,....I think?
I don't know what is the HDTV scene in Europe or Asia. Maybe they are also limited to few channels?
If you are capturing HDTV what are you using?
How many Gigabytes of Hardisk space are you taking up for 30min or 60min show?
Screen capping on computer, XviD codec misbehaving?
By CursedLemon in forum Capturing and VCRReplies: 4Last Post: 13th May 2011, 00:43 -
Problem with capping on my comp with WinDV and advc-100
By MikeMGMVE in forum Capturing and VCRReplies: 3Last Post: 2nd Oct 2008, 14:19 -
Capping BBCHD H.264 Help plz...
By 77x8 in forum DVB / IPTVReplies: 2Last Post: 14th Jul 2008, 06:16 -
What screen capping/thumbnails software is this
By Ronny G in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2008, 07:36 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
