i never burned a divx file to a vcd with nero. how is it done? is there a certain format i need to use after extracting the files from winrar? what do i burn? is this a bin and cue situation? i havent downloded movie yet but i need to know how to handle this
To put it simply, extract the file to the folder of your choice. Then I suggest using TMPGEnc to convert the file to a VCD compliant format since Nero usually does a bad job of it. Then you can use Nero to burn simply by following the wizard. If you are new to using Nero the latest version (5.5.9.0) includes Nero Express and its idiot proof.... no offense intended! You can find more information in the how-to guides posted on this site.
winrar problem
By catonic2206 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2009, 11:27 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
problems with winrar
By kennyjunior in forum Video ConversionReplies: 1Last Post: 19th Nov 2007, 12:00 -
Splitting with winrar?
By chronic777 in forum Off topicReplies: 0Last Post: 17th Aug 2007, 07:17 -
Winrar error
By alintatoc in forum Newbie / General discussionsReplies: 17Last Post: 28th Jul 2007, 06:04
