  1. I have run Many Many .Avi Movie files through VirtualDub to pull out the audio & make a .Wav file which I use when I run the .Avi through TMPGenc with the .Avi to make an Mpeg1 file.
    However, this last .Avi file I loaded into VirtualDub the same as I always do but I got this error message "The Requested audio compression is not compatible with the input format. Check that the sampling rate & channel count of the input matches those of the requested format".
    When I load my .Avi, I go to Audio & check "Full Processing" & then fo to File & check "Save Wav", Am I missing something?
    -Thanks-
    Mick
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Your avi might have a ac3 encoded audio stream.
    Or you simply don't have the audio codec installed.
    Do a search on encoding ac3 to a wav file. It's been discussed at great length. This should get you all set.
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  3. Member spidey's Avatar
    Apr 2001
    U.S.A.
    ~~~Spidey~~~
  4. Thanks Spidey:
    I just tried it & I think it worked! The true test will be what it sounds like in my DVD Player.
    -Thanks Again-
    Mick
