I ripped my first dvd to svcd and the video always has little lines running across the screen. Is this normal or is there something I can do?
For the encoding I used TMPGEnc with Motion search precision as High Quality, Constant bitrate (use fitcd to calculate bitrate), non-interlace. Can anyone help?
Soulds like your using the wrong 'Aspect Ratio'
Then in your encoder(ie-TMPG)Like this:
I used to have the same probalem.
Hope this helps.
As always thanx to Sefy's guide for the pix.
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 20:44 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32
