is it possible to convert a divx 3 video into a divx 4 video, and if so will i lose any of the quality and what program works best for that.
also whats a good program for changing the demisions on movies, ive got a bunch of tv series and thier all different resolutions (352x240,352x232,384x288,352x181) i wanna make it so there all the same sizes
thanks
VirtualDub would allow you to change both the resolution and the compression codec used. (i.e. DivX3 to DivX4)
However, both of these changes would require re-encoding which would almost certainly result in quality loss.
Question on VHS Capture vs DV Transfer to PC
By VideoTechMan in forum Capturing and VCRReplies: 36Last Post: 3rd May 2012, 06:57 -
Newbie - Question regarding VOB to DVD transfer?
By Greggles in forum Newbie / General discussionsReplies: 5Last Post: 19th Oct 2010, 16:37 -
Video transfer question
By Greg_NY1 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Oct 2009, 10:30 -
Data transfer speed/ability question PC to PS3
By GLE3 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2009, 16:06 -
Cam transfer question
By Hal1000 in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2007, 05:44
