How do i convert a 12.5 or a 14.93 fps movie that has been downloaded, to a frame rate that when played back on my dvd player, will play without any judders. i.e. at a suitable frame rate like 25 or 29 fps.
I am using TMPGEnc, and have tried so many variations without succsess.
Thanx,
Thanx,
Billybob -
if you convert a 12.5fps movie to, say, PAL at 25fps, each frame will be played twice. So the resulting (S)VCD will look juddery. There is nothing (AFAIK) that you can do to fix this. If your source to target framerate is not a simple multiple of one to the other it will look even worse.
In my opinion the result of such conversions is so bad its not generally worth the effort. Sorry.
fps conversion in Avidemux
By AlanHK in forum Video ConversionReplies: 4Last Post: 5th Dec 2009, 04:58 -
60 fps to 30 fps conversion -- It looks terrible
By usps_postal in forum EditingReplies: 6Last Post: 18th Sep 2009, 21:09 -
TMPGenc TS FPS Conversion
By leftofcool in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 07:39 -
Conversion out of Sync, probably cause=FPS?
By Day44 in forum Video ConversionReplies: 2Last Post: 7th Jul 2008, 14:30 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
