Alright i am wondering how i can re encode the vcds i made to svcd. I did a search on the forum but didnt find anything.
BOb
Easy, use TmpGenc. But why bother, they wont get any better.
Garbage in = Garbage out -
how exactly in tmpgenc would you do this. I mean ripping the vcds onto my hard drive? Thanks
Use VCDGear to convert the .dat file on the VCD to an MPG. Then TMPGenc to re-encode.
But as Bugster says - it's probably as good as you're going to get already. The only reason I can think to do this is maybe to add subtitles? -
You can convert the dat files back into mpg files (see the "how to convert" link on the left), then convert them to SVCD-compliant MPEG-2 files from there.
If you need to do this because your player will play SVCD, but not VCD, that's one thing.
However, if you think it will improve the quality of your 1150kbit MPEG-1 files, you will achieve nothing, other than having a larger file that looks no better than the VCD from which it came.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Yeah i just want to get them to the svcd because my dvd player will just play svcd and not the vcds. Thanks for all your help
ripping dvds to hard drive in a singe file
By angryassdrummer in forum Newbie / General discussionsReplies: 10Last Post: 8th Jan 2011, 07:05 -
Exact Copy of DVD made in Poland from Hard Drive of LG recorder
By dubronidog in forum MacReplies: 5Last Post: 18th Nov 2010, 10:14 -
Ripping my dvd's to external hard drive......
By nodollas in forum DVD RippingReplies: 11Last Post: 30th Jan 2010, 11:57 -
Ripping to External hard drive
By mercuryguy in forum MacReplies: 5Last Post: 25th Jan 2008, 14:10 -
Copy home-made DVDs to my computer hard-drive
By CdnMark in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2007, 00:50
