Does adding subtitles using to avi and encoding to vcd cause
the file to be biger?
and does the quality of the movie stays the same?
thanks. 8)
meant to say using virtual dub to tmpgenc program.
and is there different in the size of the vcd with subtitles to the vcd with out subtitles and also if there is a different in the quality. -
Adding subtitles will make NO difference to filesize in a standard VCD.
Quality should remain the same as well - although some people may argue the sharp subtitle lettering is difficult for the MPEG algorithm to compress efficiently (i.e. produce artifacts)
adding subtitles to AVI (xvid or divx) WITHOUT re-compressing
By truthlesshero in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 10:43 -
adding subtitles to avi file
By dragonhead08 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jan 2009, 08:18 -
Help Adding Subtitles to an AVI while converting to an MPEG
By canas15 in forum ffmpegX general discussionReplies: 8Last Post: 26th Dec 2008, 23:28 -
Adding subtitles to an AVI
By ker-plop in forum MacReplies: 12Last Post: 8th Oct 2007, 08:48 -
Adding Subtitles To An .AVI File
By thesal523 in forum SubtitleReplies: 2Last Post: 10th Aug 2007, 12:16
