Hi again guys.
I have now got my HDD replaced and have got a completely clean install of XP.
I have installed the ASPI divers from Adaptec for XP.
I have installed CloneAD and read the user guide thoroughly
I have installed DVD2VCD and TMPG
CloneAD reads the DVD info OK but when I click on start it just quickly flashes to the progress bar then back to status bar.
If I select No IFO Parsing and select RIP entire DVD, it progresses but creates very very small VOB's.
Is there anything I am missing?
Using AMD XP1700+, 512Mb Ram, XP.
Backing up Con Air (R2)
I am have exactly the same problem as you are. I have been browsing FAQ's for a few hours now, have not found an answer.
I am using CLAD DVD XP 1.3 in Windows 2K.
I downloaded and installed ASPI 4.71.
On closer inspection I just ran aspi check and now it says I am back to 4.5.7 even though I ran the 4.71. What gives?!
Well, I am going to work on that issue for now.
If anyone has an answer as to why CladDVD runs and shows progress for ripping a DVD (took around 6 minutes) but then the resulting file is less than 1 meg in size.. help would be greatly appreciated!
Thanks All
LS -
open the ripped vob files in dvd2avi and preview/scan what is on the vob files, that might give a hint.
also you can go to nero (ahead) homepage and they have a wnaspi32.dll you can download. whenever I have a program that has a aspi problem I just drag and drop this dll into the root directory for that program and usually fixes it.
MultiAVCHD - what am i doing wrong?
By rz514 in forum Authoring (DVD)Replies: 15Last Post: 13th Feb 2012, 11:23 -
AutoMKV - am I doing this wrong?
By Phat J in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 02:50 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
