  1. 8) hi all, ive got some svcd & vcd that i want to add menus and chapters to. ive read the authors section as how to do it but the file formats of these films are DAT FILES then it says avseq01. none of the programmes i have tried recognise these files. do i need to convert them back and if so what do i use and how do i do it
    thanx
    Netherlands
    First you copy the DAT-file to your harddisk.
    See the guidehttp:
    //www.vcdhelp.com/convertdat.htm
  3. Convert?
    Click on that link over on the left (those are links, many of them), "How to...convert"
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  4. Banned
    Jun 2001
    UK
    thanx
    You probably wont need to convert the dat file, if its already a VCD mpeg just use it as it is. If you want to play the .dat movie just double click it and select open with Media Player.
    If you really want to change it back to a standard Mpeg without the VCD headers, use VCDGear
