Can anyone help me out and tell me why I cannot capture in Winproducer/Wincoder at 720x576 Pal?? The only option when I click on the output profile when in the Nvidia WDM Video Capture box is 352x288?
However when you click the profiles at the top you can select pal dvd full which is 720x576..
The only program that I find that will capture at 720x576 is Powerdirector but that has some macrovision protection on it that I cannot find out how to remove.. This is only when I try and record from, for example, Digital Tv on certain channels..
Is there anyway that Winproducer can be made to capture at 720x576 or is there any other capture software that anyone can reccomend that will do Pal 720x576???
Any help is much appreciated
Sean
P4 1.8g Northwood
512mb 333 Memory
Asus P4B266 M/B
MSI Gforce 4 4600 (vivo) 128mb
Sb Live 1024
Realmagic Hollywood + dvd decoder card
250 gig of hard drive (split over 3 drives)
Plextor 40x cd writer
Pioneer A04 dvd sriter
Relisys 17' TFT monitor
Both VirtualDub and AVI_IO support custom capturing resolutions.
I don't know if they will work correctly with your card though - maybe someone who has specific experience could tell you.
Download both from the Tools section on this site and give it a go.
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 11:49 -
Capture analogue with 720x576 has tiny horizontal bar at bottom
By ManUtdFans in forum Capturing and VCRReplies: 15Last Post: 21st Jan 2009, 14:12 -
Help. Convert menu sublayer from 720x576 to 720x480 (PAL to NTSC)
By danfisherman in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2009, 12:56 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49 -
DVD TO DivX (PAL 720x576 16:9 Letterboxed)
By SamFisher in forum DVD RippingReplies: 16Last Post: 10th Jul 2007, 20:17
