Hi -
is there a way to change the fps of a mpg ? like I have a mpg2 that was encoded at 25fps but I need 29 fps.
thanks ; )
The only way to change the fps of an mpg is to transcode it. The easiest way to do this would be to use TMPGenc. If your making a compliant svcd than you can simply load the appropriate template. You'd really be better off converting to ntscfilm (23.976fps) instead of ntsc (29.97fps.) For svcds, theres really no reason to convert to 29.97fps unless that is the fps of your source. In all other cases 23.976fps will give better quality and cause less problems.
AnonymousGuest
Just quick question about FPS:
In my newbie beginnings transforming an asf to mpg could a
value of 0.166 in FPS be enough to throw off the video/audio sync?
The asf (Now avi) has a fps of 23.810. The NTSC Film setting in TMPGEnc
has 23.976
I am almost bald (pulling my hair out) trying to figure out the sync
problem. I am going to be trying some fixes late Sunday night but
any input would be appreciated.
Thanks.
P.S. Is there a formula for converting the amount of time you need
to correct the gap? You need to enter the time in milliseconds but
since I am not to "up" on math right now what would be the equivalent
of 2 seconds in milliseconds? 2000 or 2000000 (milli=millionths Correct)? -
Think of millimeters.
milli=1/1000
http://www.metric.fsworld.co.uk/siprefix.htmAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
How to change 30 fps to 29.97 fps ?
By pchan in forum Video ConversionReplies: 5Last Post: 9th Feb 2012, 19:57 -
How to change MKV from 50 fps to 25 fps skipping every second frame?
By andreyyshore in forum EditingReplies: 11Last Post: 5th Feb 2011, 15:09 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 05:53 -
Change FPS
By maza1967 in forum Video Streaming DownloadingReplies: 8Last Post: 9th Mar 2010, 19:52 -
change the fps of one video, is possible ?
By yanlong in forum Newbie / General discussionsReplies: 20Last Post: 26th Jul 2008, 21:52
