i have a .wmv file and want to put it on VCD. Supposedly TMPGEnc supports this file type but i was having trouble so i checked the guide here. It said to rename the file to .asf, but i don't know how to do that! Do i just ad a '.asf' to the end of the filename? or do i need to do something more complicated?
plz help me out
thx a lot!
AnonymousGuest
Just right click on the file and choose "Rename".
Click at the end of the file name after the . and delete
the wmv and type in asf
If that doesn't work then you may need to run it thru Graphedit.
Do a search for the user name of "kenetik". There is a
great guide, step - by - step for using Graphedit.
Believe me I have had my share of troubles just recently
with asf's and wmv's. I can try to help you but I am sorta
new at this also. But, give what I said a try and if it doesn't work
then post again. I usually cannot answer until after 6pm EST
Mon-Fri. So please be patient and I will return.
Goodluck.
Automatic subtitle renaming
By notme1 in forum SubtitleReplies: 2Last Post: 5th Apr 2010, 13:49 -
converting to 3g2, anything better than Quick Media Converter?
By logic7 in forum Video ConversionReplies: 1Last Post: 28th Jan 2010, 03:19 -
converting Quick Time
By butterflies in forum Video ConversionReplies: 12Last Post: 4th Dec 2009, 08:36 -
bulk/auto renaming
By chewie8008 in forum ComputerReplies: 7Last Post: 18th Feb 2008, 17:11 -
Quick question - PAL Menu when converting NTSC Xvid
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Oct 2007, 11:46
