I try to rip starship troopers dvd, when i use smartripper, it check no dvd, then i use window xplorer to trace the vob file but none only the video folder w/o vob file.... anyone can help me plz??? thank's!!!
Try first opening the DVD with a DVD Player, probably PowerDVD or WinDVD. Usually this 'unlocks' the DVD, enabling for further usage.
I did try dvd player and it's working! but if i use powerdvd or windvd it's working? i rtied to using windows explorer to seacrh the vob file but none, what should I do?
Did you mean you tried PowerDVD/WinDVD and it DIDNT work? Or it DOES work?
i meant i tried powerdvd/windvd but it didn't work!
or maybe it use another format beside vob file?
thank's
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
