Hey All - Two Questions:
I'm trying to check the FPS of a few different files - mostly .MOV's, Quicktimes, and .ASFs so I can properly convert them in TMPGEnc (if I choose the wrong FPS no sound comes out) - VirtualDub won't read any of these file types. Are there Virtual Dub specific Codecs or another program I can use to check the FPS on these?
Also, for FPS rates of 15 or so (especially occurs with Quicktime movies) what do you recommend for converting? TMPGEnc won't do sound with anything that is not categorized into 24, 25, 29 (for VCD) - and I can't separate the audio into a WAV with VirtualDub since it is a Quicktime file.
Thanks in advance!
Results 1 to 1 of 1
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 04:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
