ok...i have some quicktime movies i want to put on vcd...so i downloaded bink and smacker to convert it to .avi but it doesn't add the sound to it...whats a free program that i record the audio? or is there something better than bink and smaker that will convert with the audio...please tell me..i'm clueless
There is a much better way, use TMPG with the QTreader plugin. It will take a MOV file and encode it directly to VCD. You can find both here in the tools section. Just unzip the plugin into the same directory as tmpg.
