  1. I'm downloading it now!!!!!!!!
  2. oh sure another version,when is 6 coming out?........let us know if its any better ok?........still using 5578
  3. Changes from Nero 5.5.8.2 to 5.5.9.0
    Bug Fixes:
    -Fixed bug, that caused Nero to treat empty directories as files, if they were cut and pasted in an ISO compilation
    -When creating a DVD-Video compilation using the Nero-Wizard, ISO filesystem was generated instead of ISO/UDF which causes DVD-Video disks not to play on stand alone DVD players
    -Fixed CD-Extra audio session problems that occured with some recorders
    -Modified Erase CD-RW/DVD+RW/DVD-RW Dialog
    -Fixed DVD-RW full erase
    Features Added:
    -Added Nero Express !!! For Nero Express features please see the Nero Express product info page.
    -Added several new recorders.
    -Allow MRW-Media to be erased before pre-master burning
    -Files can be dragged and dropped from a CD or DVD drive into a compilation
    -Display compilation size and media capacity in the warning dialog for overburning.
    -Allow switching of the medium type while burning ".iso" images.
    Release date: July 4th, 2002
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  4. http://www.xp-erience.org/article.php?sid=2734
    here's a site great for xp/plus that upgrade........
    let us know what u think.......
  5. Nero Express ROCKS! Finally I can say "Nero is as easy to use as NTI cd-maker".Can't comment on DVD apps.but Express burned a cd-r in half the
    time as Burning Rom.
