Hello!!
I have just made a backup of one of my DVD movies...
But the size of it is 2 gigabytes, and i want to have them on cd's
Anyone know which program i should use to split it up in 3 files???
Plz write the programs name
I'm not sure, but try Virtual Dub... I'm sure someone will come along with better info...
wooow
That was fast - i will try it..
But anyone with experience in that kind og stuff plz answer -
if its an mpeg use the cut and merge tool, under mpeg tools in tmpgenc.
Craig -
I agree with Craig. TMPGEnc works great to chop and join files. When you open the program, cancel the wizard. Go to file and then mpeg tools. When you're there, click on the last option...cut and merge or whatever it says. Click on add, add your mpeg file, click edit. You get a new screen come up. It shows your movie and a slider. Slide it to where you want to chop it, then click the } button. Then click ok and you're back to the original box. Click on the location and make a name for the first part of your movie, then click run. Continue those steps for all 3 parts of your movie. You will have your original full movie, plus 3 parts to your movie.
Hope this helps.
TracyB99 -
Weeeeeeeeeeee
Thank you all for so fast response...
I tried TMPGEnc and it works
Once again: THANKS
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 18:32 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:28 -
Split 720P MPG File
By ap0091 in forum Video ConversionReplies: 2Last Post: 30th Aug 2008, 12:51 -
How to split a MPG file in specific parts
By bosstone75 in forum Newbie / General discussionsReplies: 8Last Post: 28th Nov 2007, 13:38 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
