Hi there.
I just finished capturing 43 minutes of footage off my VCR using VDub. The output file is 55 GB in size YUY2 704x576. I deliberately captured to uncompressed cause I want to do some slight video editing with Premiere and then encode to VCD with TMPGEnc.
I would like to know how it is possiblt to navigate through such a huge file. Premiere or VDub crash when I slide the scroll bar to the point where I want to edit. What I want to do is ad a fade out effect at the end of the clip and that's it.
I tried to shorten te work area and render only the last minute of the clip but Premiere would not render it either. The only solution is render the whole clip, but it takes 4 hours.
Any solutions on how to navigate easier through that file ?
I think that if VDub creates some keyframes while capturing, the output avi will be easier to navigate. Do you know how to add keyframes while capturing ?
Thanks in advance.
Maybe getting a stable motherboard with a lots of quality RAM and install a 8MB Cache Harddrive on a separate IDE channel without sharing the channel with your C drive?
I have found out that seeking through the file is too slow because there are no keyframes in the captured file. I am capturing with VDub at 704x576 with Uncompressed YUY2 Matrox and I thought that when capturing uncompressed avi, each frame was a keyframe too... I don't know why I have no keyframes in my avi (only delta frames).
Anyone can help ob the keyframe issue ? How can I add keyframes while capturing ?
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
Navigating to next title from the last chapter of the current one
By vdgg in forum Authoring (DVD)Replies: 3Last Post: 4th Jan 2012, 00:18 -
TMPGEnc Problem - navigating one frame at a time
By ereiamjh in forum Video ConversionReplies: 4Last Post: 28th Jul 2010, 08:55 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22
